0-5v AFR output?
Hello, Is there a way to use a spare output to create a 0-5V AFR signal to run a display gauge on a Black? I have a AEM wideband gauge currently and its inaccurate and unnecessary, I would just like to have an Innovate AFR gauge without an additional controller and sensor. I can’t use an OBD type gauge as I will not have access to the buttons to cycle the display, the gauge is embedded in the cluster and the screen wouldn’t suit the theme of the car. I assumed I could use a PWM table but AFR/ LAMBDA isn’t found in the drop down menus.
probably only way is to find can gauge which will display AFR or build custom one with custom style. I also wanted to do this because Im using spartan v2 without any gauge and would be nice to can look at afr sometimes. I’ve also thrown away AEM because of random readings. Probably easiest way is to install second wideband in downpipe :frowning:
That’s what I figured. Thanks for your input.
I would also like to know if this is doable. Seems like with all of the functionality this should be doable but unsure how to execute. Anyone know?
