6 and 8 fuel injectors not firing
Hi hope you are well
I have a pro 8 running my Mercedes m113 V8. Recently there is a misfire that has developed I noticed bank/lambda 2 is running lean. After further investigation i found injector cylinder 6 and 8 are not fueling in normal engine running. But when I test the injector outputs in the software 6 and 8 work bank2 run rich they click.
Any help would be appreciated
