Basemap To Ls engine with vvt
Hi guys,
has anyone done black or pro with Chevy LS engine that has vvt?
I didn´t find anything but LS3 and that is without vvt.
Miikka Kaskinen
There is a base map up for the DI LT1, the VVT portion would operation the same minus total movement for which ever engine you have.
Base map LT1
Great,
and does it have same setup for triggering and pwm parameters?
Yes, LT and gen 4 LS run the same triggers. The PWM cam control is also the same minus total movement.
