Blink Marine keypad with 2 encoders. PKP-3500-SI-MTR
Has any one solved the problem with the blue leds encoders being far too bright?
I’ve been implementing one manually on some non-Ecumaster hardware, and believe that will need a firmware update from Blink Marine. There are no settings anywhere in the current CAN protocol to adjust the bright of the encoder LEDs separately to the buttons.
Thanks for confirming, I will send a message to Blink Marine somehow, it’s not good and at night the only option might be to turn them off, poor solution though.
I’ve emailed Blink about this. I see their RacePad device has separate brightness settings for the encoder LEDs, rings etc, so hopefully it’s possible for them to implement.
https://blinkmarine.com/app/uploads/2024/11/Racepad_CANopen_UM.pdf (page 38 onwards)
Blink Marine have replied saying it’s not supported currently, but that they’re working on an update that will add a setting to change the encoder LED brightness. They suggested I email again in a couple of weeks for an update, so sounds like it could be available reasonably soon.
Thanks for the update
