# BMW M54B30 - Engine set up/injector phase
**URL:** <https://community.ecumaster.com/t/bmw-m54b30-engine-set-up-injector-phase/2022>\
**Category:** V3 SOFTWARE\
**Created:** [August 10, 2024, 8:33pm UTC](https://community.ecumaster.com/t/bmw-m54b30-engine-set-up-injector-phase/2022 "2024-08-10T20:33:10Z")\
**Posts on this page:** 1\
**Showing post:** 15
<div class="post-metadata">
**Author:** ![tombate911](https://avatars.discourse-cdn.com/v4/letter/t/ecb155/32.png) [@tombate911](https://community.ecumaster.com/u/tombate911)\
**Post date:** [December 12, 2025, 10:12am UTC](https://community.ecumaster.com/t/bmw-m54b30-engine-set-up-injector-phase/2022/15 "2025-12-12T10:12:51Z")
</div>
Have a look at the following post. This is tuned for 272/256 Schrick cams.
I have my file posted here.
> [@Version 3.059 Release Candidate #2](https://community.ecumaster.com/t/version-3-059-release-candidate-2/4711/25):
> Wanted the check the following is correct, I noticed when I lift of the PPS 100% to 0% the DBW is being taken from the Idle, where I thought it would be taken from the DBW table until the conditions for idle are met. I realise that this is possible because in the Overrun settings I do not have the override dbw section selected. However in idle parameters Idle is only on if Map over 25kpa. I have added in some Overun DBW %’s now, which has also made me notice there is no overrun fuel, just com…
_[View the full topic](https://community.ecumaster.com/t/bmw-m54b30-engine-set-up-injector-phase/2022)._
