# Dq250 dsg cxx vr6turbo
**URL:** https://community.ecumaster.com/t/dq250-dsg-cxx-vr6turbo/275
**Category:** EMU BLACK / CLASSIC
**Created:** [October 31, 2023, 7:32pm UTC](https://community.ecumaster.com/t/dq250-dsg-cxx-vr6turbo/275 "2023-10-31T19:32:46Z")
**Posts on this page:** 1
**Showing post:** 11
<div class="post-metadata">
### Author: ![keybo](https://avatars.discourse-cdn.com/v4/letter/k/9e8a1a/32.png) [@keybo](https://community.ecumaster.com/u/keybo)
#### Post date: [February 20, 2024, 5:38am UTC](https://community.ecumaster.com/t/dq250-dsg-cxx-vr6turbo/275/11 "2024-02-20T05:38:49Z")
</div>
Is your problem solved? It seems that he has the same problem.
> [@EMU Black - ABS Coding in CAN setup](https://community.ecumaster.com/t/emu-black-abs-coding-in-can-setup/744):
> Howdy ECU Master peeps. I have a 2010 2.0TSI 4motion Tiguan with a VW Passat BWS R36 turbo’d engine swap running a EMU Black ECU. I am trying to get the ABS working and have 2 errors in VCDS to say that the ABS pump has lost its code. Plus lights are on the dash. I believe this is what is stopping the Haldex working too. The codes in VCDS are, ABS Module Hardware :- 5N0 614 109 M 01314 - Engine Control Module 000 - - 01044 - Control Module Incorrectly Coded 000 - - I have tried several co…
_[View the full topic](https://community.ecumaster.com/t/dq250-dsg-cxx-vr6turbo/275)._
