EMU Classic – compatibility with OEM Volvo T6 ignition coils
I’m installing an ECUMaster EMU Classic on a Volvo B6284T 2.8 twin-turbo 6cyl engine.
I’m retaining the original Volvo ignition coils:
  • Volvo part number: 30713416
  • Bosch reference: 0 221 604 001 / 008
  • Coils have integrated ignition amplifiers.
According to Volvo VIDA, the original ECU provides a positive ignition-control pulse of approximately 2.5 V, with approximately 2 ms dwell at idle. The signal is LOW between pulses.
Before connecting the coils, could you please confirm:
  1. What voltage does the EMU Classic output in active-coil mode? What are its output current limits and electrical characteristics?
  2. Can the EMU Classic drive these specific Bosch/Volvo coils directly without risking damage to the coils or ECU?
  3. If not, what signal-conditioning circuit or interface do you recommend? Please specify any required resistor values or voltage limits.
  4. What ignition output polarity, dwell configuration and grounding arrangement do you recommend for these coils?
I want to confirm electrical compatibility before powering the ignition system.
If anyone could provide any info i’d be very grateful guys.
Thank you.
just stop using AI bullshit
Cheers for the absolutely useless answer mate.
Trying to keep the ECU and coils safe, couldn’t find anything in the documentation, so hence I asked a genuine question.
For what it’s worth I just put the scope on mine and measured just over 7 volts at the coil. It was a noisy signal picking up a half volt square from something else that I might need to investigate further but whatever.
I’m running BLACK not Classic, however I wouldn’t be surprised if the two systems run similar numbers.
Might need a Dev to enter the chat for confirmation.
