Emu Pro IGN-1A Coil Wiring
Hi all,
I’m running an EMU Pro 16 on a Mazda 13B-REW with IGN-1A coils.
Question about the coil wiring: where should Pin B (signal ground) of the IGN-1A connect on the EMU Pro 16?
  • PGND
  • Analog ground
  • Digital ground
br,
Bastian
I’m 99% sure I connected mine to analog ground.
Analog Ground, (Signal ground)
It should be connected to the ECU’s power ground with a dedicated wire all the way to the ECU connector. The coil’s main ground should go to the cylinder head.
It doesn’t matter that it’s a signal.
What matters is where it’s connected.
And it’s connected to the ignition output.
Ignition outputs for an active coil switch between an 8 V supply and power ground. That’s why the coil trigger ground should also connect to power ground, but use a dedicated wire so the coil doesn’t see any voltage drop on the existing power-ground connections.
Reply to both analog ground.
The ECU pinout states:
Power Ground
Digital Ground
Ananlog Ground
Power ground needs to be connected to the engine.
All low side outputs will route the current to the Power ground (engine)
Analog Ground is reference for Analog inputs. Do not connect this to the engine
Didigtal Ground is reference for Digital inputs. Do not connect this to the engine
As mkuklis_ECUMASTER writes:
Ground the coils to the same point as the power ground. No the IGN output shares the same ground with the coil and there will be no potiential voltage differance.
The Output grond of the coil would be best to place it at the rotor housing of each individual rotor.
The knock sensor bolt hole would be the best spot, near the spark plugs.
