Gen 5 LT throttlebody
Hey, I had a gen 5 lt dbw that i was thinking of using, but found out it was controlled using SENT protocoll, is this only useable with GDI driver? or can i use it somehow anyways? and have no ide how to wire it up since i thought it was like normal dbw with 2 analogs, H-bridge, +5v and sensor ground :sweat_smile:
DI driver is sent. Motor + and - go to ecu h bridge. 5v, 0v, and Sent Sig go to DI Driver. No other way. Also, the bypass throttle is SENT as well. Wire the same as primary throttle.
Thanks, then ill have to change throttlebody​:wink:
