New account, so the site will not let me upload. I have the project, a log of the catch and die, and a cranking scope. https://drive.google.com/file/d/1ZUQoBJsEneuav0LlCfkz12KDG58zVeB1/view?usp=sharing <–Maybe a link is allowed?
EMU Black, V3. Nissan L28E, about 10:1, 2818 cc, no idle valve. Sequential fuel and spark. D581 LS coils, (0280158085) 430cc injectors. MAP-referenced regulator, base pressure 350 kPa. Speed density.
Trigger is a 24-2 optical disc in the distributor, so it is cam speed. One sensor only. Three wires: 12 V, signal, sensor ground.
- Primary: CAM toothed wheel with 2 missing teeth
- Num teeth, including missing: 12
- Edge: Falling
- First trigger tooth: 6
- Trigger angle: 72
- Cranking gap detection scale: 100%
- CAM sync tooth window: off
- Secondary trigger: Do not use
- Invert phase: on
- Firing order: 1-5-3-6-2-4
It reaches Synchronized while cranking. Timing light on cylinder 1, ignition lock at 10, lines up with the 10 mark on the pulley. It catches and RPM climbs to roughly 600–1000, then it dies. Same thing with the throttle held open. Invert phase off kicks back on the starter, so I left it on. Wasted spark changed nothing.
Power to the ECU, coils, injectors, and distributor is present in ON and in START. Fuel pressure holds about 3.5 bar until RPM falls, then the pump shuts off. No lambda, oil, or fuel-pressure protection is on. Fuel cut is 6000 rpm and 200 kPa MAP. Cam sync trigger tooth stays at 0, which I think is because there is no second cam sensor.
The laptop AFR does not follow the gauge, so I am not using it.
Question: with sync held and cylinder 1 on the timing mark, what could be causing it to fire and then die as soon as it is running? i get no more than 2 sec runtime
