Misfires right after peak boost, eventually clears up
Hi all,
vehicle; 1990 mazda miata,
4 cylinder 1.6
640cc injectors
Garret 2560R turbo
Toyota coil on plug conversion
EMU Black
Currently chasing this issue together my enginebuilder/tuner but we can’t seem to find whats causing this; at WOT right after peak boost the engine sputters and then will clear up for the last bit of rev range. It will happen regardless of boostpressure, lowered it down from 1.1bar to 0.5bar but it still happens and at roughly the same RPM. Doesn’t seem to happen at anything less than 100% throttle.
I’ve swapped the CAS. Tested with new coils, new wireloom for the coils, new plugs, gapped to .5mm. Tried different dwell times. Im kind of lost now, most signals in the log (i think?) look pretty okay except for the wiggly MAP and fluctuating rpm signal when the sputter happens. I can’t seem to find any abnormal corrections being triggered or some kind of limiter that gets activated
I’ve ran a different ECU before the EMU BLACK and hadn’t had this sputtering issue (had different issue with that ECU but that’s another story). So i want to believe my components are proven but maybe along the way some component did start to fail? Or did we set up the EMU Black incorrectly?
I dont know much about tuning or ECU settings so if i left out any important details please let me know. I’m currently at a loss, any advice and guidance would be greatly appreciated.
You can see it happen around 33 minutes
20261026_1815.emublog3 (1.9 MB)
adriaan 26-10-26.emub3 (69.1 KB)
Your Dwell at 14v seems very low.
I doubt you have anywhere near the spark energy required for a boosted application.
How did you decide on these dwell numbers? You mentioned you have tried different dwell times.
Does your tuner have the tools to check the Current Ramp on the Coil Primary Winding to observe full Coil Primary saturation so they can correctly tune the coil dwell table?
I would start with investigating the actual Coil Dwell time for those coils. A Scope with a Low Amp current clamp is the only way to get this right if you don’t have the manufacturer data.
