NB miata (bp4w) cam sync issue after V3 migration
NB scope looks good.
What I would do now:
  1. change primary trigger edge to falling
  2. change CAM 1 edge to falling
  3. Set igntion mode to: seqentional instead wasted spark
Btw: Update to 36-2 trigger is great improvement of this ignition trigger. The more tooth the more precise is the spark (less dependent of angular acceleration of the crankshaft).
scope_202658_180.emubscp3 (592 Bytes)
Okay, so I tested with falling edge trigger on crank/cam + sequential ignition. Sorry I forgot to enable ‘take skipped edges’ this time…
Had to adjust the base timing with the timing light using a different first trigger tooth / angle setting.
Car didn’t want to start up, it was trying to fire but sounded like it was working against itself.
Any other ideas based on this info?
I see the problem now.
The rpm are uneven and the cam decoder doesnt work properly (N+1).
Try the following settings on the CAM:
Im going to switch back to v3 this weekend and try this. Should primary trigger still be set to falling edge with this secondary trigger setting?
I haven’t had the chance to try, did this work?
