Pressure and temperature oil sensor
Hi everyone, I have a question. Does the ECUmaster control unit’s oil pressure sensor have an oil temperature sensor inside? If not, which one is the correct one? Thanks for the reply.
More info required. Which sensor are you referring to? Is it a Bosch part? What part number?
no, no Bosch spare part and the sensor must be placed near the oil filter
Good luck then. I’m out.
Ok thanks for helping
The question is just a bit confusing, maybe because of a translation issue. Maybe post some pictures of what you’re looking at? If you’re looking for calibration preset for a specific sensor, more than likely that doesn’t exist and you’ll have to make your own
Ah ok, so i create a sensor probably or use a 2 sensors. Thanks all for reply
You could get the bosch temp/pressure sensor if you want 1sensor to get both of the info, otherwise u need to use 2 sensors. Bosch nr. 0261230340
U need to use 2 analog for the temp/pressure sensor
Ah ok thanks for the code
Ok, thanks for the information
