Problem with DBW/DBW tuner EMU PRO 8
I have a problem with our custom throttle body. Based on our calculations we have a well-matched electric motor with the appropriate gear ratios. We assembled everything on the table and throttle body close itself with a spring without any problem. After wiring everything and turning on ecu (even with option “Disable when no rpm”) the motor offers greater resistance. This also happens when the DBW has a safety error. Why is this happening, and is there a way for the motor to provide the same resistance without being connected to the ECU?
Best Regards,
Dominik
H-bridge outputs are always set to either ground or battery voltage.
When throttle control is disabled, both outputs sit at ground.
That means the motor coil is basically shorted.
When you spin this motor, you have a generator that has maximum load (short).
This requires extra work, so the motor moves more slowly at the same force/torque.
This is how braking is realized in an electric motor.
I am not sure why this is relevant or needed.
Yes, you can get the same effect without being connected to the ECU.
Just short the motor wires.
But I don’t understand the point.
You shouldn’t be concerned about this.
Please describe your actual issue.
Why are we talking about this?
How is this a problem?
This is interesting to hear.
I wouldn’t expect this behavior from a ‘faulted’ or ‘disabled’ H-bridge either.
In my experiences, a faulted/disabled H-bridge results in a ‘floating’ or ‘freewheeling’ situation where the spring takes over. What if you’re at a 100% load and a fault occurs? It’s not ok for the spring to take longer to pull the blade down to a limp position. Braking is not what you want in this situation.
I don’t remember the exact details.
I think we disable the H-bridge depending on the error.
I would have to check the code.
When the H-bridge is disabled, its outputs float and don’t brake.
But you are right. In general, faults should disable the H-bridge to close the throttle as fast as possible.
Thanks for your reply.
The main problem is the resistance generated by the electric motor when the ECU is on, regardless of the DBW safety state. This prevents the throttle from closing fully when the ECU Master is active, which results in the DBW tuner not passing through and poses a safety hazard on the track. It is essential that this resistance be eliminated, given the particular attention paid to the vehicle’s overall weight and the throttle’s high position.
I hope I’ve cleared up any doubts
Best Regads,
The solution you want is not possible.
And that’s not how the system should work.
First, if the motor speed is 0, the braking force is also 0.
Your description doesn’t make sense.
It looks like you are making the wrong assumptions.
Please provide the data for the issue you are seeing. If you’re having problems with the DBW tuner, please post a screenshot from the DBW tuner after a calibration attempt, along with a log recording the calibration process.
I think there might have been a misunderstanding, so let me clarify the exact issue we are facing.
We are working on a project with a custom DBW throttle body. Mechanically, we have properly matched the spring force, electric motor force, and gear ratio. When unpowered, the return spring has plenty of force to snap the throttle butterfly back to the limp-home position from any angle.
However, the problem appears once it is connected to the ECU. After powering the ECU on and activating the “Disable when no RPM” setting, the motor creates so much electrical resistance that the spring can no longer return the butterfly to the limp position. This resistance is exactly why we are failing the DBW calibration process.
We did manage to get the DBW calibration to complete successfully once, and the throttle responded exactly as it should. But, when we intentionally disconnected the TPS to trigger the DBW safety state, the throttle butterfly once again got stuck and couldn’t return fully to limp.
So, my question is: Is it possible to configure the ECU to drop the H-bridge motor driver into a high-impedance (freewheeling) state rather than a braking state when “Disable when no RPM” or the DBW Safety state is triggered? We need to remove this electrical resistance so our mechanical spring can do its job correctly.
I hope that I clarified everything correctly this time.
Best Regads and sorry for misunderstanding.
