S50B30 Stock NA Basemap
Hello Guys,
I hope you are doing well.
We’ve been working on getting our S50B30 (european) to work on EMU classic and it’s been a struggle. The engine starts and idle but too rich. Using pure Alpha N it responds well to throttle input but else idles fairly poorly. It does not use the stock MAF sensor and has been converted to MAP. As most S50b30 it uses the stock ITBs.
The engine is fully stock and all sensors are responding well.
We’ve used the only basemap we’ve found, an S50 turbo basemap, but we did make some change as the turbo was probably pushing quite a lot of boost (there was retard ignition at high load mid rpm !) and used M50B25 iginition maps I found in OEM ECUs (I’m pretty familiar with OEM ECUs).
I will link there Logs and the map as we’ve made it until now: S50B30 And idle logs
Specificity, for the time being the idle solenoid is not cabled and idle is obtained by preloading the throttle cable. It is a choice from my friend and I thought it might be an issue for TPS Idle On and Off… But it’s not clear if it does
A basemap for an atm version would be very helpful, but any help is of course welcomed and cherished :slight_smile:
Thank you,
Tim :slight_smile:
