Hi Jadzwin, will you implement this feature on the next version? We are waiting to test this function.
Yes, but rememebr that we send juat upshift message but it depends on the gearbox if it shifts up. For example if there will be wheel spin it probably not shift immediately
Thank you! Great job ![]()
Yes we are aware of that! We will use GPS to CAN too but we already modified the DQ500 TCU tune for wheelspin.
Do you have an estimation when you will publish the next version?
Good day. I’ll repost the message in this thread. Could you add an “Autotune VE cell” function triggered by a hotkey (so that the value is immediately updated based on the target AFR and Short term correction)? (This feature is available in MaxxECU; it’s very convenient.)
I would really like to have an auto-calibration feature in the “Injector Wizard”, so that the ECU could switch the injection mode or AFR Target and obtain “Injector cal” values.
I think de1phi’s proposal is a good one.
Haltech has this same feature that I use a lot on the dyno to rough things in: QuickTune
@erfouro Have a look here for more details. From here the upshift feature resulted. ![]()
Currently I have FWD DQ250 car and I have pretty good and solid results with custom function with order V3 version (3.063).
I have something like that (which reads from OEM MK60 ABS from 4 wheels and configured driven / undriven axle):
I am updating soon to FWD DQ500 and willing to test the new functionallity. ![]()
You can use swtich as a 2 position rotary switch.
