Lest talk about time base rev limiter function.
As per the other thread, this feature is incredibly useful for launching FWD drag cars. in combination with slipping the clutch it allows the car to gain actual road speed without letting the tire spin up to redline and gain an uncontrollable amount of momentum in an instant that is nearly impossible to tame. This also allows for the launch control to be set relatively aggressively to basically eliminate any chance of a bog related to prep conditions or at the very least give you a bigger window of margin and be confident going towards the more aggressive end. This also eliminates the problem of trying to utilize traction control at very low speeds were it is going to be more difficult.
This feature is available as a preset or easily made with custom tables in every other comparable ecu.
Below is the same screenshot from the previous thread showing how a non-linear curve is preferred since the car is able to gain traction at a non-linear rate.
Below is another image showing the rpm limiter in green (desired and actual) and the orange showing the wheel slip plummeting as traction is quickly gained.
@kimbaku @KK_Autoteknik Please add any examples or use cases if you are able
Sorry, I don’t have any logs available. We use it for anti-cavitation control on a turbocharged Sea-Doo jet ski.
The launch control function that has been developed is probably very good, depending on the setup. However, in my experience, once the launch button is released at the start, we already have the boost pressure we need.
I therefore think it would be better if the system could switch directly from launch control to a standard RPM limiter. This would avoid having to retard the ignition timing after launch
Ideally, the launch function would handle the initial start, and once the button is released, the ECU would seamlessly switch to a normal RPM limit without further ignition retard.
In my opinion, this will provide a smoother start, and the car will often have sufficient power that needs to be controlled where a rpm limit will be great
This is a cool idea that’s likely much easier to tune than RPM based traction control. I imagine adding Timers as options for “Custom rev limit input” should make this possible.
In my experience, the timer function is great for creating various clever setups; you simply start a timer, and the desired function kicks in. MoTeC offers extensive capabilities in this area, and it is crucial that these functions can be triggered or activated by a wide range of events—for instance, after a launch or based on a specific TPS percentage. MoTeC allows a function to be triggered, for example, once the throttle position exceeds 85%. Once the timer expires, the function cannot be activated again until a new cycle begins. We use this on jet skis, where the initial trigger activates the function automatically, eliminating the need for a dedicated button.
Hi ![]()
Yes that is right and that is perfect the next i hope you built is
- Rpm limit
- E-throttle % opening
so i think we can be most bette to make good start for front wheel drive i rallycross
Thank you for being willing to help and listen to what we would like to see in your software; it is a pleasure working with Ecumaster.
I’m a little worried about throttle as you last the control over it.
If something goes wrong (eg, the car start to slide) you will dont have a control over the throttle.
Maybe it should be % of throttle opening. Then it will be always lower or equial your target position.
yes you might be right
if you could make the e-gas target for example 100% of the normal target, could we reduce the target over time? then we would be able to achieve the desired reduction of power from the engine
Excellent news. Thank you so much, I appreciate you!
% throttle opening over a timer would be excellent. I use the max throttle by gear table a lot but being able to have more fun be tuned control during the launch but not limit the whole gear will be beneficial for sure and I think will work better then by speed as well
Yes. So you can enter 100% for the throtthe target from table or 10% what will close the throttle partially. So in worst case scenario the trhrootle will be closed not fully open.
