V3 3.068 Lambda and AFR test
Today Tested Lambda sensor LSU4.9 (in free air) and AFR oscillating 13.8-14.1
My lambda target is 0.94 and Lambda 1 oscillating 0.94-0.96
Tested on 2 different Ecumaster Black ecus, same result. Will try on LSU4.2 same test when sensor will arrive.
In free air AFR should show around 21 why it is 14?
this car had wiring problem, now sorted lambda show good.
But i tested LSU4.2 on 2 cars and 2 ecus with lambda outside of exhaust in fresh air. Both show AFR 7.2(should be 21) and Lambda 1 goes lean to 2.49. So Lambda 1 looks good but afr goes other way to very rich.
I Test 2 Lambda 4.9 on Short time and Check this extra with Lambdatool maybe 0,01-0,02 on different…. Test Area about Lambda 1.00 so thats nothing….
