The latest version of V3 Studio is now available! In this release, I’ve focused on improving the user interface based on your feedback.
In the next post, you’ll find a link to a short video where I walk you through the most important changes.
More information can be found in the change log.
Changes 3.071b
WINDOWS CLIENT
Fixed an issue with window refreshing.
Fixed flickering in window captions.
Fixed the graphics for selected checkboxes.
Values entered in variable numerical fields are now immediately converted to integers and limited to the allowed range
Changes 3.071
WINDOWS CLIENT
Power usage optimized to extend laptop battery life.
Partial project export, import and merge functionality added.
Current pinout can now be exported to an HTML file.
Initialization masks are now handled correctly during undo operations.
GUI
DPI scaling improved.
General appearance improved.
Main tree view search performance improved.
Main tree view updated with EMU PRO icons.
“Engineering Green” color scheme added for dark mode.
Display issues occurring in dark mode after resuming from hibernation fixed.
TUNE DISPLAY
- Lambda display can now be switched to AFR by double-clicking or right-clicking the display.
GRAPH LOG
Performance significantly improved, reducing laptop battery usage.
Dynamic frame rate added for smoother scrolling.
Vertical scaling improved.
Shift + mouse wheel behavior improved.
Background rendering for values displayed at the cursor fixed.
3D TABLES
New circular position indicator added.
History lines added. Visibility can be toggled using the toolbar icon or the H key.
Issue with assigning turbo shaft speed to the X axis of the custom boost DC correction table fixed.
2D TABLES
- Values can now be adjusted using the Up and Down arrow keys.
SCATTER PLOT
- Performance significantly improved.
VARIABLE WINDOWS
Numerical values can now be entered directly into numeric fields.
Boolean values can now be toggled using the Space key.
VVTi
- 2D kP correction tables added.
IDLE
- Support added for three-wire PWM idle control valves without a return spring.
DSG
- Start-blocking flag is now cleared when importing an EMU BLACK project with DSG configured into EMU CLASSIC.
BT CAN
- TPS value handling updated for eDash compatibility.
