V3 studio 3.073b [LATEST VERSION] [UPDATE]
Botch chanells are available in your log:
The “Cranking” state was not recorded in the ECU State log (Inactive->Cranking(missing)->AfterStart), and the “Synchronising” mode was not recorded in the “Trigger sync status” (Nosync->Synchronising(missing)->Syncronised)
I can see it now. I will check. Thank you
  • Added automatic DSG upshifts based on vehicle speed from the non-driven axle.
New season will be fun! :smiley:
Thank you!
Your rpm at the begining of the cranking goes up to 445 RPM what is probably above cranking threshold. So the ECU changes state to afterstart.
What is your trigger and settings ?
Here You are
It very strange, my starter cant rotate engine so fast. Usually rpm on cranking 150-200.
Trigger Jeep 18-2-2 + Hemi Cam.
My scope available via link V3 studio 3.070 - #51 by de1phi
It seems like initial rpm calculation issue for your tigger not your real cranking speed. I will take a look.
Renix 44-2-2 trigger
I know this trigger is not of much interest for the Renix trigger but maybe someone can help.
As I understand from the manual, you can run only as much spark advance as is your trigger angle, in my case 35 deg.
My engine, stock Renault J7R 752 with a modern Garrett turbo, requires as much as 52 deg. of advance in the cruise area.
It does not matter what I set as the “First trigger tooth”, the trigger angle will remain the same.
I tried tooth one to tooth 4, it will always require 35 deg. to align with TDC (checked with strobe).
Is this the limitation of the trigger pattern, a bug o am I doing something wrong?
Attached trigger logs with first trigger tooth =1 @ 35 deg and 4 @35 deg.
4-35o.emubscp3 (599 Bytes)
1-35os.emubscp3 (609 Bytes)
@Jadzwin_ECUMASTER would it be possible not to have the cam angle tables connected like the fuel table, for example if the rpm were to be changed on table 1 that table 2 does not change as a result - basically having them somewhat independent.
i believe this will give me the ability to have wider rpm range on lift with my 2zzge engine.
I updated to 3.073b and my tps wouldn’t go below 10% regardless of 0% voltage. Downgrading to 3.072 it is fine. I am on EMU Classic
Could you post your base map and log ?
Do you want the log in 3.072 or 3.073?
The 3.073. I will check what is the problem
20261110_1742_3072_changeto3073.emublog3 (68.5 KB) It’s very odd, small throttle inputs go below 10%, no throttle input sits at 10%. And 100% throttle drops instantly down. This log starts in 3.072 then changes to 3.073 at around 55s when you see the throttle position change to 10%
I have sent an email, just wondering if this is something you’ll be looking into, though I understand that it probably isn’t a priority.
When will it be possible to import maps from V1 Classic in V3 Studio?
I wanted to ask the same thing im still on v1.227
I think there is a bug in the idle airflow PID controller; it only works when I apply a small amount of idle ignition correction and only in the cells where I have entered numbers, while in other cells without modifications where it is set to zero, it stops working.
I need 12 cylinder support in V3, any plans to implement that in V3?
