engine ls2
2 independent ecu master lambda controllers for bank 1 and bank 2, both on can1 at 1mbs. together with pmu and adu whellspeed2can and egt2can.
Controller set on address 644 works correctly on emu, second on 664 is not showing any data, on light client both controllers work correctly an display same lambda value, latest fw for controllers.
Propper settings for oxygen sensors on emu also done.
Also Egt2can displays correct values on client and on adu over can, but on emu the values oscillate very rapidly from min to max on all 8 cyl.
would appreciate asap help, tomorrow car must go on dyno, will doit any way with light client opened on second lambda.
thank you
