Adu pejo 206 2004 gtı
I have an idea. Can I read Can Bus data using USB to Can?
You don’t have the 0x128 frame on your CAN bus, so the data you need is most likely on another frame, assuming that this data is available in your car’s CAN networ
Once you have a preview of the real CAN frames in your CAN network, you can easily find what you need.
Just turn on the left indicator and look for the changing bytes in the Light Client window. Then do the same with the other signals and enter what you find into the ADU.
There was a van-bun line in the vehicle and I learned that this type of information was obtained from there.
This transmission line is different. Do you have any information about this line?
We do not support this kind of communication.
I have one last question. Can we connect the +12V signal terminals to the ADU display?
I need to take triggers from the right and left long and short signals and connect them to the ADU.
Do you mean connecting a digital/analog input to the ADU Display? Yes, you can.
Yes, 12v input won’t harm the battery, right?
No, it should be fine.
How can I add an odometer using Ecumaster ADU?
ADU manual, page 172 and following.
