Are there recommendations of a suitable flyback circuit for these outputs?
Ill be connecting 3 injectors to injector output 6 and another 3 to AUX1.
This wording confused me the first time as well, for injectors you DO NOT want flyback diodes.
If you use them to control like a boost solenoid, then you would need a flyback diode. Any PWM type signal.
I think you’re using them for staged injection, 3 injectors sounds like a lot for 1 output. Check how low your impedance gets doing that, and if it matters your deadtime data will probably be off doing putting them in parallel.
Thanks for the reply, I see what you mean the statement is a little confusing, these are 12ohm injectors and the help section does say up to four high impedance per channel is fine.
I understand the dead time will be different (from a single injector) so ill be testing the deadtimes to make sure theyre correct.
