Base Maps - BMW M54B30
New to the brand and tuning, I have an e30 with a BMW M54B30. I am looking for a base map, any ideas where I could find one?
How’d you go finding a basemap?
What ECU? what setup? I have for turbo conversation with emu pro 8 if needed
HI “gtengines” would you like to share your map ? I Am currently working on wiring up Emu Pro 8 to my forged M54B30 with G30-770. Base Map would be very handy to get all trigers right . Thanks
2024_09_18_Feco_1.emupro (26.4 KB) You welcome :wink:
Hi, “gtengines” try this calibration file for CLT (2.2K ohm), IAT (2.2K ohm), OILT (2.2K ohm), I calculate this based on MS43 sensor calibration for stock sensor. I take in to acocunt stock MS43 has a diffrent pull up resistor, 828 Ohm for CLT, 2.49K ohm for IAT and 828 ohm for OilT. So tabels was caculated to suite Emu Pro 2.2K resistor .
Sensor Calibration.zip (1.5 KB)
Im doesnt use OEM sensors except coolant return temperature from cooler…
