CAN communication problem
Hi everyone,
I have a problem with my Adu I try to communicate with mektronic ecu I connect the ecu to the can 2 Line, I have the terminal resistor at the 2 end of the line, I see in the adu software can 2 ok but I didn’t receive the data at my adress, I have the communication protocol but I didn’t see anything can you help me ?
Thank you all
Try checking with Light Client whether there are any frames on the bus.
Hi, Angelo84!
i connected MectroniK MKE1 to the ADU
I only have a problem with CAN communication: when i start the car it detects a temperature of over 110° on the CLT and IAT, obviously unreal and for an istant.
If you need the parameters to configure the CAn network , i can help you
