Emu black 2jz gte vvti
Just got my emu black from mail today along with the plug and and play wire harness. anyone got a map that will work? i tried the maps online but its making me idle super rich at afr at 10 causing lots of black smoke at idle. please help
change injector size to fit you injectors
Check if map sensor is connected to the intake manifold. Without it will run in the wrong section of the fuel map.
A basemap is not to drive around with checking or changing parts.
The car needs to be mapped.
honestly dont know what im doing
where can i pay someone to be
drivable again.
my buddy gave me a csv file he told me to use how would i upload that into the fuel tables
Did you get it running right?
nope i was at a deadend. i decided to plug back factory ecu since it was giving me a headache and didnt wanna break anything
Well the base startup map on the website is just that, a start up map only. It is not going to run right until it is tuned properly. Maybe you can have that done if you know a shop near you? Doesn’t necessarily have to go on a dyno but it needs to be tuned properly
are you be willing to offer these services?
If you want to email me, we could try and get some stuff lined out for you.
that would be greatly appreciated!
I sent you a direct message. Did you see that?
