Hello, Hero 13 and Mission 1 GPS data is supported? When I add in the files, Datamaster latest beta can’t do auto sync. Thanks
We are working on adding support for GoPro 12+. Could you share a test video from Mission 1? We don’t have one in our test suite.
As for the timeline, we plan to release a big Data Master update by the end of August, with this support included.
i have a 2 and a 5 gig sample, where should i upload? would be great if it would work with DM. even just the lrv file, which can be faster.
You canuse WeTransfer.com. My mail is michal.kowalski@ecumaster.com
sent a shorter video, link is valid for 3 days
Thank you, I have the video now. Do you have the adulog from that session?
i’ve sent the session, but it’s very short.
Now i’ve tested longer, 20 minute sessions, and it looks like the perfect sync goes away lap by lap.
Do you have maybe a multiplier, so a video can be played like 99.9% speed, so it matches, or some other workaround, which keeps that in sync?
i don’t think it’s a mission 1 specific issue, maybe it has to do with 59.9 fps vs 60, idk
Thanks, I have seen your log. I’ll check the sync over longer periods.
Support for Hero 13 and Mission 1 added in New Data Master software version 2026.3.
It should also correct the video syncing issue with longer videos/logs. Let me know if the issue persists..
