IDLE Mode switching
Is there a simple way how to switch idle mode between “heat-up” “normal” and “cooldown” modes ?
We would like to heat-up engine fast, easy done with agressive timimgn retard, normal is smooth normal idle, and rotational idle to cool down engine fast. Yes, we can program us arround with some table, corrections, rules etc…
With the newest version, you can easily change the ignition angle target for idle because it’s now a separate table where you can add your own axis.
For the rotational idle, we still need to add an easy way to do it natively.
