New ADU software version 122.0.1-beta is now available.
What’s new:
- Fixed incorrect CANBus Export element content after upgrading firmware from versions lower
than 122.0 to 122.0 (affecting ADU Client 122.0).
If you upgraded firmware using ADU Client 122.0 (released 26 March 2026), your CANBus
Export elements may be corrupted. To resolve this, reload your project using ADU Client
122.0.1.
Your project was automatically saved during the upgrade and can be found at:
C:\Users\<user>\Documents\ADU\<your_device_name_or_sn>\yyyymmdd_hhmm_ss_FIRMWARE_UPGRADE.adu
Download the update here: https://www.ecumaster.com/tv
Additionally, a new how-to document covering the setup of the Gear Calculator introduced in 122.0 is now available: https://ecumaster.com/files/ADU/HowTo/How_to_Configure_Gear_Calculator_in_ADU.pdf
Sincerely,
The Ecumaster Team
I just identified that I have this issue and appear that some of my CAN exports are corrupted.
At the same time, I am not able to connect to my ADU to make any changes. Trying to identify I cannot connect. It shows “Disconnected” vs Offline when nothing plugged in. I can see lots of data in Lite Client, but not individual modules.
I’m not sure if I understand what is your current issue and what you have done so far. More details would be helpful.
- Can’t you connect to ADU anymore?
- From which firmware version to which version did you upgrade?
- Could you share your project file from before the upgrade and the one with the “corrupted” CAN Bus exports? You can share them here or via email: maciej.fudala@ecumaster.com
Did you have both ADU client and Light client running at the same time?
Further investigation, I now don’t believe my file was corrupted, but having some sort of CANBus problem which is not allowing me to connect to the ADU or PMU. The issues that caused me to start looking at the PMU seem to have gone away and everything is functioning correctly at the moment, so I won’t spend much more time on this at the moment.
We’re at the track at the moment, so as long as stuff is working, I’m OK for now.
