Looking at adding a PMU to my setup
if i was to wire in a fuel pressure and temp sensor to the PMU how would i then use those sensors through my emu black ?
Ben
Ben
On the PMU you’ll send a CAN export on an unused address.
On the Black you’ll configure to receive the message sent. Use the “user defined CAN stream”
Send the raw input voltage value and calibrate in the Black. It can’t directly a pressure value.
Connect sensors to pmu analogue 9 to 16. They transmitted from pmu and recieved on black without any additional setting. Analogue 9 will be your can analogue 1 at ecu Analogue 10 will be can analogue 2 at ecu . This is done default no other settings need to be changed. Use those voltaged on sensor callibration at ecu.
Thanks for the replies looks like it will
Work how I want it too just wanted to check before I bought one ![]()
