I have a Honda K series with VTEC (controled as VVTI switched).
When I run the VE Tuner for a Switched Table 2 and try to apply the changes it applies to the Table 1.
Can you add an additional filter for the VE Tunner?
Unfortunately VE Tuner does not support 4D tables at this time. However, there is a dedicated VE correction table for VVT switched. You can find it in VVT / Switched / Corrections / Volumetric efficiency adder. There are also corrections available for lambda target and ignition angle.
Can you scope one more change for the VE tunner.
It would be very cool to enhance the visual part of the VE tunner when a cell is selected on the Proposed VE table same cell on the actual VE Table to be highlighted somehow. I found myself focusing a lot to find where and what change it proposes.
BTW: any progress on the 4D VE tunner support?
Yes, we are going to add the VE table selection.
4D is also on todo list, but no timeline yet. There is a workaround for this (by copying the modified table), but I know it’s not user friendly.
