Hi ,I am new here ,just bough emu black for my project car mazda mx-3 . I ‘am swapping there 2.5V6 KLDE from MX-6 and also adding turbocharger there
. I need some help with basic map . Please can someone helpe somehow . Thank you, it will really help me .
well aren’t you lucky aha, I’ve been toying with a KLDE and a Black when I have spare time.
626 adapter base r5.5 - minor driveability improvements.emub (146.6 KB)
Don’t just slap this file on the car and call it good, i’m 90% sure base timing is off by 5* (need to adjust the disty anyway and verify with a timing light) but this runs and drives my 626 just fine. However I am doing a lot of science experiments and there’s a lot of weird stuff built into this map, so take the basics and start clean.
Ah thank you , it was impossible to find it somewhere on net , i just want it to start the motor and then adjust it ,i am also adding turbocharger there,but at the fist i will need to run engine few hundred/tousand km (cuz i am changing everything inside ),and if everything willl be allright i add it then,so lot of work and fun waiting xd
… so it will also need to go to some profi tune guy ,he is few km from my garage so need to drive there . Really thank you bro I really appreciate it
Hi bro,i got some problem now ,i build the whole motor just now starting with normal ecu ,i done ecumaster emu black now there,and the distributor is not giving spark ,Please ,do you got some pinouts of stock ECU or how you made it running Thank you for answering.
