Hi, I have a device that needs uses a control signal with 5V PWM at 50-100 Hz, do you guys see any problem if I connect a 5V rail to the device and use the ADU auxiliary output as my 0V line in order to feed that 5V PWM into this device? Does anybody see any problem with this idea?
