Bummer. The new base maps require a Pro 16. I’m using a Pro 8. Sigh. I guess I open them offline and copy/paste?
We made this limitation because this base map is designed to work with our adapter that will be sold with PRO 16. Removing that limitation could be confusing for people using our adapters, but we will discuss it.
For now, open the software without a connection to the ECU and generate the base map. Then you can convert that map to a PRO 8 project and load it into your ECU, or export only the wanted parts and import them into your current project.
