CANTcu intergration V2
Hi. have a customers E34 M5 turbo that has a 8hp76 trans fitted with CANTcu. also has a dbw fitted using a e46 throttle actuator and VW golf5 pedal. Emu Black is using V2 software V2.178.
1st unit i am working with and learning the ins and outs.
Trans has a 8hp75 tcu and valvebody fitted. need some assistance or advise with Emu black intergration. Have ecu configured as per CANTcu wiki page/guide and using CANTcu software 1.0.142.
Having a issue with gearchange between 1st to 2nd being harsh and 2nd to 3rd being very harsh.
Not sure what to check/alter/set etc.
Had a stock flash and then OEM+ but still the same harsh shifts. i disabled 1st gear and it was a bit better but the 2nd to 3rd change was still harsh. have to be very smooth and slow with the accelerator to get past 3rd and then its ok although changes from 5-8 changed very quick. cadjusted pedal sensitivity but no difference. weary of damaging the transmission with how agressive the shifts are. map attached and configuration info
cantcu_ecumaster_integration_v1.pdf (341.9 KB)
replies and feedback appreciated.
MoM5T2.emub (146.6 KB)
