Can you confirm that I understand the logic behind triggers for the button functions in the ADU?
First, are the channel states 0 (off) and 1 (on) or is it 0 (off) and other-than-zero (on)?
For “Press” I assume the button function fires on a off to on transition
For “Release” I assume it fires on a on to off transition
For “Click” I’m assume it fires on a on to off transition but only if there was a off to to transition proceeding it within some maximum time window (what is the window?)
For “Hold” I’m assume it fires when a off to on transition has then been maintained for a minimum time (what is the timer?)
Is that correct? I’m trying to design my data structures for integrating some 3rd party CANBus Input devices and don’t want to make assumptions.
