Adu with bmw Edc16 obd
Hi there
i have a request to install an ADU in a bmw m57 engine, this engine is controlled by a bosch edc16 ecu with canbus,
does the adu work with the obd protocol of this engine/ecu?
regards
Hi, depends on whether the OBD data is over the CAN bus.
If it’s a car from 2008 or newer, the OBD is guaranteed to use the CAN bus.
Before that, it’s different for each model of the car.
I am trying to connect Adu 7 with M57 -2003. But without success. Please help!
Check if you have ODB data over the can bus, most likely not if your car is from 2003(as Marek wrote above). ODB in ADU works only over the CANBus.
