AIM Smarty Cam can with ADU
HI thanks for the ad
Question has anyone intergrated their AIM Smarty Cam 3 into their ADU what I’m trying to achieve is to have an icon on the ADU when the camera is recording ?
Cheers Paul
Paul,
Thats a simple task. If you enable the standalone ecu CAN, then select an ecu, an option will pop up at the bottom for camera status over CAN. From there, set your address and then setup the ADU. If you need a custom inbound ecu template or just a generic blank template to enable the export feature, you can make one in AIM software.
Do you mean enable the stand alone ECU CAN in the Aim software?
When I checked yesterday I could see the Aim unit sending anything on to the CAN.
Yes, you have to in the AIM software like the picture I provided.
great thanks -sorry i didnt recognise the Aim software
Got it all working - thanks for the help!
