Anyone available for remote tuning?
Ive got a mk4 vr6 turbo 4motion, it is running on a base map currently and i can drive it up and down the road, however i am on quite a tight schedule to get the car “ready” and i cannot get a dyno slot in time (i started trying to book a slot over a month ago). By this i mean i want the boost mapped in just on spring pressure and get the car to a stage where it’s comfortable going through the revs. Ive still got around 2 and a half weeks till i need the car ready so let me know if anyone can help me out. Here are the mods:
Golf r32 bfh pnp emu black
forged rods
Headspacer 8.5:1 compression (estimated)
GTX3582R (china turbo)
Siemens deka 630cc injectors
4 bar fuel pressure regulator
Deatschwerks DW65v fuel pump
Golf r32 throttle body
MAC valve boost controller fitted
IAT sensor fitted
MAP sensor fitted (BOSCH 0 261 230 120)
TIAL 44mm wastegate 0.5 bar spring in currently
Standard lambda sensors
3” downpipe
2.5” intercooler piping
SPEC stage 3 clutch with lightweight flywheel
standard coilpacks
standard sparkplugs can swap these to NGK DCPR9EIX
Drop me a private message I can put you in touch with someone. I’ll message him now to check he can do it and get his number for you.
This guy is who I was going to recommended
Not sure why the post was deleted
Hi I have s13 with a ca18det engine running ecu master black. Do you know any remote tuners. Any help.would be appreciated. Thanks
