Battery Isolator issue
Hi, this maybe something simple but if I have the emergency kill switch enabled as soon as I crank the engine it cuts the power. I’ve increased the delay time to see what’s going on and I can see the emergency kill is going true.
Question is why as it’s happy with everything else on until I go to crank?
Thanks in advance
you can see that emergency kill is active so I would check connections there…
Yes, it is only active once the engine starts cranking.
Just checked wiring and all ok.
Issue solved! The kill switch had too much resistance :smirk:
