Hello everyone,
I finally made my car work properly at idle and wanted to continue to tune it up further. The problem I have is that after accelerating (doesn’t matter the amount) the car firstly loses some rpm and then it increases. Is it an Acc enrichment problem?
Thank you!
What does your wideband sensor read at this moment?
Yes its an acc rnrichment Problem…share project.
This is a quick log and some values for the enrichments. if you need anything else please let me know (I dont know how to upload the .emu file)
20260817_0953.emulog (152.4 KB)
Its running a little rich now, I need to fix the VE table a little, I will attach a little log.
U upload it the same as the logfile.
Sorry, the file you are trying to upload is not authorized (authorized extensions: jpg, jpeg, png, gif, heic, heif, webp, avif, emub, dbc, adu, pmu, txt, pdf, doc, docx, csv, emublog3, emub3, emupro, emuprolog, emuproscp, zip, emubscp3, bgc, bgg, bg3, adulog, pmulog, emublog, emulog, xml).
This is the message I get when I try to upload the .emu file.
Interessting. But u can zip it.
I didn’t think about this:))
WinRAR ZIP archive nou.zip (13.1 KB)
U should also fix ur knock sensor settings…u have permanantely a ignition retard by 15 by knock.
And here:
U can try Enable full group inj…this will help with ur issue. Then i would paly with Acc sustain rate…i learned that there was something buggy in old SW and i set it to 0. But i think full group will help a lot.
Yes!! It helped a lot to enable full group inj.
Thank you!!
