Det3 launch control
Could you please explain how to wire the DET3 to activate the Launch Control using a switch? I would like to know the specific connections and setup needed to enable this function.
Thank you very much!
hello fred…
Read the manual on the DET3 webpage , has 3 form to conect the switch button and explain the configuration.
I read the manual but I don’t really understand. If I put voice number 3 with a switch to ground, is it good?
