DFPR correction table is disabled?
Why DFPR correction table is disabled ?
This table generates automatically when you setup your Fuel pressure and Base pressure parameters. It is not intended to be modified by the user as it base on physical model.
In the future this table will not be visible to the user.
Hi Jadzwin, Base pressure- pressure on idle, or presssure with 100kpa MAP?
based pressure referenced to baro. So if you have FPR MAP referenced it is a pressure when the engine is not running.
Thank you. Clear now
