Hey,
I am looking some information about using internal MAP as the BARO sensor and its benefits or problems…
I have for some reason turned on the Baro setting in Map,Baro parameters to Use interman MAP as BARO and also in fuelling general enable baro correction. I dont remember why but I think it was when I was trying to solve lean issue when pressing gas pedal fast.
So what is the benefit of using this option in the first place and is there a down sides on using them?
My car is audi S4 v6 biturbo and im using Emu Black v3 version 3.047 and the newest firmare.
So one problem I have noticed that when I have the baro settings like this
Is that the boost shown in the graph shows 50kpa/g lower than it is comapired to map reading like this. Is there any other down sides with using these baro setting than this 50 kpg/a offset?
The fun part is that if I turn off these baro sensor settings, the offset is correct. but then I will have a problem where the fuel pressure correlation goes up to 10-12 and I got 20kw less power in dyno.
I have now made the VE table and Ignition table with the baro settings on because it was noticed I had it on after tuning for a while.
So is there anything I could to to get rid of the baro settings and still get the corrrect fuel pressure correlation and power, or do I now have to live with the offset. and other issues that the baro settings are causing?
here is my map and testing log with and without the baro settings and 2 dyno runs where one has the baro enabled and one disabled.
(edit) these dyno runs 23 and 24 made around same power. but run 25-26 after them made 20kw less, with same settings. the fuel pressure Correlation however can be seen bethween run 23 and 24.
audi s4 22.04.2025.emub3 (69.5 KB)
audi s4 22.04.2025.emublog3 (2.3 MB)
00023.emublog3 (875.3 KB)
00024.emublog3 (267.0 KB)
00025-26.emublog3 (575.2 KB)
