Hello is it possible or is there plan to allow for additional DBW % in response to delta tq/rpm signal from exernal transmission controller?
My DCT runs with CanTCU and can send over CAN delta rpm or delta tq value. (Ie what the existing engine rpm is vs transmission target RPM based on calculated value/wheel speeds/diff ratios etc)
Is it possible to have a table delta tq/rpm vs engine rpm and then in cells a value for additional DBW throttle input?
When these cells are active then it will allow for the desired additional opening on the DBW.
Will allow for finer control on downshift blips.
I see there is a similar graph already in the automatic dsg menus.
Many thanks,
Harjun.
