I can’t get throttle blip working.
Setup:
- EMU Black
- Sequential gearbox
- Paddle shifters (solenoids controller by EMU)
- DBW
Upshifts work perfectly fine, gear cut is being enabled.
Downshifts work too but there is no throttle blip.
Any tips what might be wrong?
It turned out that it was all good with the config. You can use the above screenshot as a reference for your setup
There was an issue with DBW so we couldn’t feel the blip, but you can clearly see 3 spikes in DBW target
Hi just a quick question, what does the “Paddle up/down solenoid hold off” means there is no documentation to know exactly what it does?
I am a memeber of a formula student team and would be great if you could help us with this
Thank you
Best regards
