EDL-1 interface to emu classic together with canbus module
I would like to know if it is possible to interface the EDL-1 to the ecumaster classic emu if you already have a canbus module connected to it?
The canbus module is only used for its additional analog inputs, the canbus side of it isn’t used for anything.
I was thinking in the line of doubling up on the serial wiring between the canbus module and the ext. port and setting the ext. port up for canbus module but I’m not sure if the EDL-1 wil function properly using this method.
Looking forward to your advice.
Been told, not possible.
