Hi, for my build I would like to use a universal CAN Dash with my EMU Classic. However, therefore I need to specify the output of the Ext. port to “CAN-Bus”. Currently I use this port for a EDL 1. So it currently is specified as “Ecumaster serial logger”. If I now switch to CAN stream, this would most likely mean, that I couldn’t use my EDL 1 anymore.
Do you have any ideas of how to use a CAN dash and a logging device for engine parameters at the same time with EMU Classic or is there simply no workaround for this and I have to upgrade to EMU Black?
