There is a new firmware version available for the EDL-1
https://www.ecumaster.com/files/EDL/VERSION_1_27.zip
To upgrade the firmware, copy the firmware.bin file to the root directory of an SDHC card and insert the card into the EDL-1. The upgrade process will start automatically.
During the upgrade, the LED will flash. Once the process is complete, the LED will turn solid green.
- Turn off power to the EDL-1.
- Remove the SD card from the EDL-1 and connect it to your PC.
- Delete the
EDL-INFO.TXTfile from the SD card. - Insert the SD card back into the EDL-1.
- Turn the EDL-1 back on.
Your device is now ready to use.
Change log:
- Reconfiguration of BT module communication speed sorted
- Fixed Short term trim for V3 firwmare.
