EDL Firmware 1.28
There is a new firmware version available for the EDL-1
https://www.ecumaster.com/files/EDL/VERSION_1_28.zip
HOW TO UPGRADE
  1. Copy the firmware.bin file to the root directory of an SDHC card.
  2. Insert the SDHC card into the EDL-1.
  3. The firmware upgrade will start automatically.
  4. During the upgrade, the LED will flash.
  5. When the upgrade is complete, the LED will turn solid green.
  6. Turn off the power to the EDL-1.
  7. Remove the SD card and connect it to your PC.
  8. Delete the EDL-INFO.TXT file from the SD card.
  9. Insert the SD card back into the EDL-1.
  10. Turn the power to the EDL-1 back on.
The firmware upgrade is now complete and the device is ready to use.
Change log:
  • Support for old EDL modules (different BT modules)
